MHB Field Theory - Nicholson - Splitting Fields - Section 6.3 - Example 1
Math Amateur
MHB
I am reading Nicholson: Introduction to Abstract Algebra, Section 6.3 Splitting Fields.
Example 1 reads as follows: (see attachment)
Example 1. Find an extension E \supseteq \mathbb{Z}_2 in which f(x) = x^3 + x + 1 factors completely into linear factors.
The solution reads as follows:
Solution. The polynomial f(x) is irreducible over \mathbb{Z}_2 (it has no root in \mathbb{Z}_2 ) so
E = \{ a_0 + a_1 t + a_2 t^2 \ | \ a_i \in \mathbb{Z}_2 , f(t) = 0 \}
is a field containing a root t of f(x).
Hence x + t = x - t is a factor of f(x)
The division algorithm gives f(x) = (x+t) g(x) where g(x) = x^2 + tx + (1 + t^2)
, so it suffices to show that g(x) also factors completely in E.
Trial and error give g(t^2) = 0 so g(x) = (x + t^2)(x + v) for some v \in F.
... ... etc (see attachment)
My problem is that I cannot show how g(t^2) = 0 implies that g(x) = (x + t^2)(x + v) for some v \in F.
I would appreciate some help.
Peter
[Note; This has also been posted on MHF]
There are a couple of ways to go about this:
One way is simply to divide $g(x)$ by $x + t^2$:
$g(x) = x^2 + tx + (1+t^2) = (x + t^2)(x + (t+t^2)) + (1 + t^2 + t^3 + t^4)$
$= (x + t^2)(x + (t+t^2)) + (1 + t^3) + t^2 + t(t^3)$
$= (x + t^2)(x + (t+t^2)) + t + t^2 + t(t + 1)$
(since $t^3 + t + 1 = 0$ means $t^3 = -t - 1 = t + 1$, and similarly $t^3 + 1 = -t = t$)
$= (x + t^2)(x + (t+t^2)) + t + t^2 + t + t^2 = (x + t^2)(x + (t+t^2))$
which immediately gives $v = t + t^2$.
There seems to be a typo in the book, it should read: "for some $v \in E$".
A more abstract approach is this:
We have that $g(x)$ has a root in $\Bbb Z_2(t)$, namely $t^2$, so it follows by the division algorithm that $g(x) = (x + t^2)(x + c_0)$ for some $c_0 \in \Bbb Z_2(t)$ (this is because:
$a \in F$ is a root of $f(x) \in F[x] \iff (x - a)|f(x)$ for any field $F$. The other factor must be linear because the degree of $g$ is 2, and the factor $x + t^2$ is linear).
By the uniqueness of this factorization, we can take $v = c_0$.
Multiplying this out, we obtain:
$x^2 + tx + (1 + t^2) = g(x) = x^2 + (t^2 + v)x + t^2v$ yielding:
$t = t^2 + v$
$v = t - t^2 = t + t^2$.
It might be helpful to keep in mind this basic fact:
for any polynomial $p(x) \in F[x]$ for any field $F$, and any $a \in F$ we have:
$p(x) + q(x)(x - a) + r(x)$ with deg(r) < deg($x-a$) = 1, or $r(x) = 0$, that is:
$r$ is a CONSTANT polynomial. Which one? Clearly, $p(a)$, that is:
$p(x) = (x - a)q(x) + p(a)$.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
