- #3,921
WWGD
- 10,789
I found the answer through meditation : Hom, Hom,...Ibix said:...and only if it's got the right transformation laws.
Only for physicists. For me it's only important how many asterisks are involved! That's sufficient for me to know what to do. And don't bring up co- and contravariances. My book about homological algebra uses them differently anyway.Ibix said:...and only if it's got the right transformation laws.
OK, but still you have a condition over and above being a square matrix. The Christoffel connection coefficients are representible by an NxNxN matrix, but aren't a tensor.fresh_42 said:Only for physicists. For me it's only important how many asterisks are involved! That's sufficient for me to know what to do. And don't bring up co- and contravariances. My book about homological algebra uses them differently anyway.
But isn't a matrix just a 2D array? Or maybe it is the confusion of notational/definitional differencees?Ibix said:OK, but still you have a condition over and above being a square matrix. The Christoffel connection coefficients are representible by an NxNxN matrix, but aren't a tensor.
What type of or theory of Homology are you using?fresh_42 said:Every "rectangle" collection of numbers in any dimension can be interpreted as a tensor, a cube is just #\sum x \otimes y \otimes z##.
Covariance and contravariance determines, whether a functor keeps the direction of mapping arrows or converts them. I have never seen a second category by the way physicists use these terms - there are always only vector spaces present. If at all, it's the transition ##V \rightarrow V^*##, but they attach it to either ##V## or ##V^*##, so again no second category.WWGD said:What type of or theory of Homology are you using?
This looks more like geometric algebra. Or Simplicial.fresh_42 said:It's the old discussion what a transformation and what its matrix is. A tensor to me is simply an element of a tensor algebra, resp. space, if only tensors of equal rank are involved. As soon as I have a basis of the constituent vector spaces, I have a cube or whatever a matrix (not necessarily square) in higher dimensions shall be called. Their use by physicists makes me dizzy. It always sounds curved somehow, but it's flat as a board.
No, it looks like homological algebra, the category thingies, at least the books are titled so, both, the English and the German ones.WWGD said:This looks more like geometric algebra. Or Simplicial.
So it depends on what "is" is?Ibix said:Can be interpreted as, sure. But can be interpreted otherwise too (e.g. the connection). So I object to the "is" part of "a matrix is a tensor".
Insight?fresh_42 said:Can someone please find a word for "Erkenntnis". The only possibility I see is "knowledge", but there is a fundamental difference between knowing something and understood something! Too bad we don't have philosophy here. I would be very interested which consequences it has to a society, that only knows things and doesn't care about "Erkenntnis".
And, no, re-cognition doesn't count. It's only to realize what's already known. I'm looking for the knowledge behind "Eureka!".
Oh, I haven't thought about this one. Probably because it means something different in German. Insight here reflects on a revised and corrected position, or the possibility to view formerly closed documents.Jonathan Scott said:Insight?
They're more or less a product of chromatic aberration, yes. I'm not sure you can really call it chromatic aberration when it's not part of an optical system designed to form an achromatic image, but it's the same root cause, certainly.OmCheeto said:Are rainbows chromatic aberrations, or vice versa?
I play boulesfresh_42 said:I've incidentally found a place in town today where people can actually play boules - people who played it inclusively.
Correction: Pétanque.Ibix said:I play boules
(I need no tools)
Against fools
While eating moules.
I'll be frankfresh_42 said:Correction: Pétanque.
Your turn.
You know this doesn't work with the actual pronunciation?Ibix said:I'll be frank
I play petanque
But I don't clank
'less I bring my tank.
It works with the usual anglicised pronunciation. And just Googling it (from an English computer in England, anyway) gives me the same pronunciation. How's it supposed to be pronounced?fresh_42 said:You know this doesn't work with the actual pronunciation?
Our town is considered the most multi-cultural in Germany, but I didn't know that French belong to this mixture.
[peˈtaŋkɔ]Ibix said:How's it supposed to be pronounced?
Are we talking about the Haggis people?Ibix said:Not my fault if foreigners can't pronounce their own language right.
Haggises are people? I thought they were furry creatures with one leg shorter than the other from running round hills. You catch them by scaring them into running the wrong way round a hill, then catching them in a net as they roll down the hill.fresh_42 said:Are we talking about the Haggis people?
I always suspected these things were alive - no wonder Nessie is hiding. ... Are they related to fried Mars bars?Ibix said:Haggises are people? I thought they were furry creatures with one leg shorter than the other from running round hills. You catch them by scaring them into running the wrong way round a hill, then catching them in a net as they roll down the hill.
No - unlike haggis trapping and Nessie, those are real.fresh_42 said:I always suspected these things were alive - no wonder Nessie is hiding. ... Are they related to fried Mars bars?
Thanks! That was my thought.Ibix said:They're more or less a product of chromatic aberration, yes. I'm not sure you can really call it chromatic aberration when it's not part of an optical system designed to form an achromatic image, but it's the same root cause, certainly.
So is it the real life or is it just fantasy...?Ibix said:They're more or less a product of chromatic aberration, yes. I'm not sure you can really call it chromatic aberration when it's not part of an optical system designed to form an achromatic image, but it's the same root cause, certainly.
